ph A vállalat sok portékájának közös vonása, hogy a csatlakozóikat túlsó felükre száműző alaplapokat és az óriásira hízott VGA-kat is tárt karokkal várják.
ATi Radeon HD 5750 / 5770 / 6750 / 6770
gyiku
van, aki amd procival hajtja a kartyat?
hüllő
gyiku
gyiku
gyiku
gyiku
adott mar vki kolcson gborsnak kartyat tesztre?
hüllő
gyiku
válasz FragMaster #155 üzenetére
azert kene a 9.10, mert a gyari driver nem szokott az igazi lenni
hüllő
gyiku
gyiku
Volt-mod ATI Radeon HD 5770
vGPU
Studying Technical sheet controller L6788A find pin FB (feedback) and look for the meter a few points to make alternative volt-Mod, then measure the resistance between FB pin and the table, multiply the value obtained with the 20x and find out the approximate resistance Map of VR (Variable Resistor) to be mounted. In our case resitenta was measured 2kohm, so VR's must have a value of about 40k, so choose 50k (standardized value).vMEM
The process is exactly as if a vGPU, only here I hit a little problem. Memory controller consists of 1 phase 1 (Vdd and VDDQ) which provides voltage and voltage memories memory buffers. These voltages are independent and are each controlled by one whose face Volterra VT242 datasheet is not made public by the producing company, so we can not know for sure that Pine is FB. Doing some Internet research I managed to somehow find out which PIN FB but PCB is different (vmod site was done on HD 4890) and vmod's operation has not been confirmed. So, I prefer to not make public any plan until you are sure of its correctness.[ Módosította: 7 ]
hüllő
gyiku
Volt-mod ATI Radeon HD 5750
The steps are the same as the previous controller, so do not repeat them. In this case we have chosen a VR with a value of 100k to the value measured in the FB pin and the table was 6.3k.
vGPU
vMEM
This time we had some better luck for the controller used (uP6101) have datasheet available on the Internet site. The value measured was 5k what we indicate the use of VR with a maximum resistance of 100k. Also soldering vmod's can run directly on foot inclusive (pin 6) and mass can be used pin 3.
hüllő
gyiku
beta driverrel majdnem megvan a 4870 1gb, szvsz 9.10-11el meg is lesz.
hüllő
gyiku
hüllő
gyiku
MSI launches R5700 Graphics Cards
Afterburner, ez olyan, mint az asus tweakhüllő
gyiku
ha a 160$os 5770-ert 47k-t kernek, akkor hogy lehet, hogy a 150$os wdtv live ugyanott 30k alatt van? [link]
Az újdonság a mai naptól kezdve érhető el kereskedelmi forgalomban, ajánlott végfelhasználói ára 150 dollár magasságában helyezkedik el. A készülék már webshopunkban is feltűnt, ahol 30000 forint alatti áron lehet hozzájutni.
tehat 10$ = 17k huf[ Szerkesztve ]
hüllő
gyiku
Prémium Radeon HD 5750 PowerColor-módra - csak hutocsere.
hüllő
gyiku
ASUS EAH5770/2DIS/1GD5 PCIE - 45.5k
hüllő
gyiku
gyiku
