- Vezetékes FÜLhallgatók
Szilícium-karbid chipekkel tompíthatnak az AI energiaéhségén
it 1 százalékot tud spórolni az Onsemi, de ez is elég lehet ahhoz, hogy 1 millió háztartást 1 évig ellássanak árammal.
Az iPhone 15 frissítésgaranciát, a 16 szép rendereket kapott
ma Sokáig hallgatott az Apple a frissítésekről, most viszont megtudtuk, mennyit garantál.
nightshadow
DIRECT LED PANEL forrás: [link]
* Screen Size 81 cm
* Resolution 1366 x768 pxl
* Brightness 300 (cd/m2)
* Dynamic contrast ratio of 100 000:1
* Response Time 5 ms
* Viewing angle (hor. / Ver.) 178 ° / 178 °RECORD READY
* Record DVB-T broadcasts on an external HDD or Flash Disk
* Methods of Recording: Timer, select a program in the EPG, direct recording by pressing the "Record"
* Playback recordings on the TV
* Approximately 2GB for 1 hour recording
* Time shift - monitoring programs with time-shift3D
* Passive 3D technology - uses polarizing filters, because no unwanted flickering and related fatigue or dizziness
* Use 3D glasses are lightweight, comfortable and without the battery without having to recharge
* 4 pcs of 3D glasses included
* Option to purchase additional glasses (Code GOG3DBRYLE)TV TUNER
* Analogue, DVB-T (MPEG2/MPEG4) tuner
* PAL / SECAM - B / G, D / K, I / I ', L / L'
* Automatic tuningPICTURE
* HD READY - ready for HDTV 1080i/720p
* Possibility to change the backlighting
* Auto Switch
* Comb filter, increases clarity and sharpnessSOUND
* NICAM stereo
* Equalizer
* Output power 2 x 6 WTELETEXT
* Fastext
* Number of Pages 1000
* ToptextFEATURES
* Sleep Timer
* Child Protection
* Game Mode
* Hotel Mode (passive)
* Full support for czechSUPPORTED FORMATS (USB)
* Support: JPEG, BMP, PNG
* Support audio formats: MP3, WMA
* Support video formats: MKV, AVI, MPG, MPE, MPEG, VOB, DAT, MP4, M4A, M4V, ASF, XviDCONNECTORS
* SCART
* Composite video / audio input
* PC input (VGA)
* PC audio input
* 2 x HDMI
* Coaxial digital audio output
* USB input
Headphone outputPOWER
* Power supply 230V/50HzGENERAL
* Pitch of holes for wall mounting 200 x 200 mm (Code HYULCDDRZAKVELKY)ACCESSORIES
* The remote control[ Szerkesztve ]
nightshadow
tehát amikor 1920x1080 as felbontás van beállítva akkor elhagy bizonyos sorokat/oszlopokat?
A Full HD jelet leskálázza a tévé 1366 x768-ra.
A 3D-re nem tudom a választ, mert engem nem érdekel, így nem ástam magamat bele a témába, de biztos lesz itt valaki, aki tudja a rá a válaszokat.
nightshadow
válasz maxika2004 #20001 üzenetére
Ezek 50Hz-es tévék. Szerintem jobban járnál a 37ES6100-el.
nightshadow
Nem rossz a 40EH6030 a kategóriájában (kb. 150k), de a 220k-ás tévék azért lényegesen jobbak, nem véletlen a 70k-ás többlet.
220k-ért megkapod a csúcs 6-os Samsungot, az ES6800-at: [link].
Sonyból pedig 225k-ért megkapod a 40HX750-et 5 év garanciával: [link]. Az a +5k a kereteden felül megér 5 év garanciát. Ezek azért lényegesen jobb tévék az EH6030-nál.[ Szerkesztve ]
nightshadow
válasz nightshadow #20072 üzenetére
Ma járt le a HX750 akció, délelőtt még 225k volt, most visszaemelte 250k-ra. Webshopokban továbbra is meg lehet kapni 222k-ért [link].
nightshadow
válasz korikmate #20108 üzenetére
A Hz inkább 3D esetén számítana, úgy tudom nem is gyártanak 100Hz-es TV-t, ami nem 3D-s Samsungéknál.
2D-nél is ugyanúgy számít. 100Hz-es tévét azért nem gyártanak már 3D nélkül, mert akkor szerintem radikálisan csökkennének a 3D-és tévék eladásai, mert többen vannak, akiket nem érdekel a 3D, legalábbis ezzel a szemüveges megoldással.
nightshadow
válasz akassha #20116 üzenetére
A mostani szórásban van valami nekem való?
Én idén többet nem ajánlok LG-t senkinek, mert egyszerűen nem lehet kiigazodni ezen a villogtatós <> valódi 100Hz dolgon, teljesen átláthatatlan az egész. Ha ez a része nem érdekel, akkor a 42LS570S elvileg a csúcs 2D-és készülékük, s az pont belefér a keretedbe. [link]
nightshadow
válasz maxika2004 #20141 üzenetére
Ott van a 42LS570S hivatalos adatlapján az mkv, meg a DTS is: [link]
- USB 2.0 videó lejátszás DivX HD, MKV
- USB 2.0 - Hang AC3 (Dolby Digital), EAC3, HAAC, AAC, Mpeg, MP3, PCM, DTS[ Szerkesztve ]
nightshadow
válasz maxika2004 #20148 üzenetére
" hivatalos adatlapján " .......hát ez csak kicsit pontosabb mint az : "eladó mondta "
Hát ezzel azért vitatkoznék, de ha neked huncutka fórumtárs válasza hitelesebb, akkor vegyél Samsungot, azok biztosan tudják.
nightshadow
válasz #03969024 #20149 üzenetére
Nos, nem tudom, milyen LG-d volt előtte, de eddig azért nagy volt itt az egyetértés az LG-k (IPS) jobb színhelyessége tárgyában...
Ezt én is vitattam, mert Samsungot és a Sonyt is be lehet kalibrálni, hogy a ΔE értéke 3 alatt legyen. Ezt csak ti LG tulajok állítottátok, s köztetek volt meg a konszenzus. De nincs jelentősége, mert nem akarok kirobbantani egy vitát, mert semmi értelme. Akinek az LG jön be, az vegyen LG-t, akinek meg a Sony, Samsung, az meg vegyen azt. Ízlésekről nincsen értelme vitázni.
nightshadow
válasz -HajTömeg- #20163 üzenetére
Egy GT30 után ne várjál sokat egy 100k körüli 40"-42"-es LCD-től, márkától függetlenül.
nightshadow
válasz -HajTömeg- #20169 üzenetére
Akkor nézd meg a Panasonic 42X50-et, az tudja a 24p-ét is, s jobb képminősége van, mint egy ilyen árú LCD-nek: [link] árak: [link]
nightshadow
válasz -HajTömeg- #20174 üzenetére
Én a Tesco-ban láttam ezt az X50-es plazmát, s mellette voltak a hasonló árú full HD LCD-ék, de az X50-nek sokkal jobb képe volt. Pedig a plazma képminőségének nem tesz jót az agyonvilágított eladótér, de még így is jobb volt a képe.
nightshadow
válasz -HajTömeg- #20176 üzenetére
Samuból van olyan (akár plazma) amit ajánlanál.
Samuból csak 6-os, vagy annál magasabb sorozatút érdemes venni. Plazmában pedig 51E530, de inkább E550-től.
nightshadow
Valaki korábban kérdezte, hogy a mozgókép felbontás pontosan mit takar. Itt egy leírás róla:
"Mozgóképfelbontás
A fizikai képfelbontás csak egy adat, sokkal többet elmond egy televízióról, hogy mekkora a mozgóképfelbontása. Képzeljük el a következő tesztet! Adott két Full HD felbontású tévé, az egyik LCD, a másik plazma. Mindkettőn megjelenítünk egy olyan ábrát, amely egy pixel vastagságú, függőleges fekete és fehér vonalak egymásutánjából áll. Az ábra gyönyörűen látszik, egészen addig, amíg el nem kezdjük mozgatni a vonalakat. Ebben az esetben a kép elmosódik, a szemünk szürkének kezdi látni. Növeljük a vonalak vastagságát egészen addig, amíg újra meg tudjuk különböztetni a fekete és fehér vonalakat egymástól. Értelemszerűen az a jobb, ha minél vékonyabb vonalak között tudunk különbséget tenni.
Az LCD legnagyobb hátránya nagyon jól látszik ennél a tesztnél. Azonos mozgatási sebesség mellett egy plazmatévén 50-100%-kal több sort tud a szemünk megkülönböztetni, mint a vetélytársánál. A plazmatévénél ez körülbelül 900 sort, az LCD tévénél pedig 450-600 sort jelent. Hozzá kell tenni, hogy az LCD tévék sem teljesen reménytelenek ebből a szempontból, LED-es háttérvilágítással az egyik koreai gyártó például biztató eredményeket ért el (800 soros felbontást). A baj csak az, hogy nagyon sok időnek kell még eltelnie ahhoz, hogy ez a megoldás a belépőszintre is eljusson, a csúcskategória pedig értelemszerűen csak keveseket érdekel.
A tesztek persze sarkított helyzetben mutatják a panelek képességeit, és a valós felhasználási körülmények között messze nem ekkora az eltérés, de ettől még tény, hogy az LCD tévéknél az utánhúzás jelensége a kép bizonyos mértékű elmosódását okozza, éppen úgy, mint egy közönséges TFT monitornál."[ Szerkesztve ]
nightshadow
válasz junior11 #20200 üzenetére
A Sony-val az a baj, hogy túl van árazva. Jó példa rá az általad linkelt tévé. 100k-ért kapsz egy HD-Ready tévét. Ráadásul ezekben az abszolút belépő szintű tévékben Bravi Engine 2 van, ami nagyon régi technika. Azóta már volt Bravia Engine 3, az is már rég kifutott, s jelenleg az X-Reality megy.
Az X-reality az EX650-el indul, de az is villogtatós 100Hz-es [link]. Valódi 100Hz-es tévéje idén a Sonynak nincsen, csak valós 200Hz-es a HX750 személyében. Csak ennyit meg nem ér egy 32”-es tévé [link].
nightshadow
válasz nightshadow #20202 üzenetére
A #20202-őt -Hajtömegnek- szántam, nem junior11-nek. Sorry
nightshadow
válasz roti86 #20227 üzenetére
Samsungnál a 6-os sorozattól van valós 100Hz, Sony-nál pedig valós 200Hz van a HX750-től (Sonynál idén nincsen valós 100Hz, csak villogtatós, lásd EX650). LG-nél jelenleg nincsenek biztos infók, hogy honnét indul a valós 100Hz.
WiNZO, maxika2004: Nézzétek, ha nektek ennyi elég a cáfolathoz, akkor ez van, nekem viszont kevés. Az említett fórumtárs szerint már a 42LS570S is valós 100Hz-es. Én maradok a hdtvtestnél. Ennek egyetlen egy oka van: idejön valaki a fórumra tanácsot kérni, hogy valós 100Hz-es tévét szeretne, van rá 200k-ja, mit ajánlunk neki. Mivel én nem szeretek másnak a pénzével hazardírozni, ezért én olyan tévét fogok neki ajánlani, ami biztos, hogy 100Hz-es. Jelen pillanatban se az 570S-ről, se az LM620-ról, s se az LM660-ról nem mondható el, mert ellentmondásosak az infók. Ettől függetlenül nekem aztán abszolút mindegy, hogy ki milyen tévét vesz, mert nem én fogom nézni, de tudatosan kerülöm az olyan ajánlásokat, amelyek ingatag lábakon állnak.
nightshadow
válasz -HajTömeg- #20261 üzenetére
2m-ről hiányozni fog a 42 colos méret szerintetek?
Szerintem igen.
nightshadow
válasz hatizsak #20313 üzenetére
"Az E5-ös szériához képest az ET5-ös tévék legnagyobb plusz szolgáltatása az, hogy megjelenik a 100 Hz-es képfrissítés lehetősége, azaz a tévé képes a meglévők közé újabb képkockákat kiszámolni, és ezzel az elmosódás mértékét csökkenteni. Erre leginkább a sportközvetítéseknél lehet szükség, amelynek megjelenítése a 42 colos E5-ös tévének nem volt éppen az erőssége. Az IFC bekapcsolásával a helyzet valóban javul – ugyanakkor a helyzetet némileg árnyalja, hogy cserébe a mozgások folyamatossága már-már természetellenes lesz (azaz jelentkezik a szappanopera hatás). A Panasonic lehetővé teszi, hogy állítsuk az IFC intenzitását is – a minimális beállítás a szappanopera hatás szempontjából jó választás, de így a funkció eredeti célja is kevésbé érvényesül." forrás: geeks.hu
LCD TV topic összevonásra került a LED TV topiccal.
Fáradjatok át a másik topicba a kérdésekkel!
- Xbox One
- Xbox Series X|S
- USB to S/PDif konverter a modern RIAA, elektroncsövekkel
- Parfüm topik
- Realme GT Master Edition - mestermunka
- Diablo IV
