- Milyen processzort vegyek?
HZoli87
Vállalkozó kedvűeknek:
COMODO Internet Security 5.0.156985.1061 BETA
Újdonságok:
NEW! Application Whitelisting Control
CIS 5.x fills the missing links that its predecessors had in this area by providing a usable application white list control.NEW! Spyware Scanner and improved malware cleaning
CIS 5.x again fulfills the missing features of its predecessors by providing a new spyware scanner which is capable of scanning the windows registry and file system.NEW! Cloud Based Antivirus Scanning
CIS 5.x has integrated the cloud based computation everywhere. From on-demand scanning to process execution control, it checks if the file is known in the cloud.NEW! Cloud Based Behavior Analysis
Instant malware analysis has been introduced to CIS 5.x making detection of unknown malware possible! Any unknown file that is sandboxed and NOT observed by COMODO before is submitted to CAMAS and results are sent to the PC in 15 minutes after the upload process is done.NEW! Game Mode
Now CIS has a game mode. Just before you start to play a game, you can switch to game mode and all the alerts will be suppressed. Virus database updates or schedules scans will also be postponed.IMPROVED! Default Deny re-engineered to improve application compatibility
Unlike CIS 4.x, CIS 5.x, by default, automatically runs every unknown executable as "Partially Limited", which is a new level introduced with CIS 5.x.IMPROVED! A New User Interface!
You will be seeing a lot of suprises with the new user interface. It is friendlier, easier and prettier. -
HZoli87
Azért csak óvatosan az Avirával, messze nem tökéletese, bár most ezt használom én is.
Én is kíváncsi lennék, hogy mikor akadt ki a memória használata az új KAV-nak, mert én használtam a bétát és a stabil verziót 1 hónapig és ilyen problémám nem volt, nem találkoztam, más probléma azért volt vele.
..... Hát akkor nem értem hogy nálad mért csinálta, ha jól tudom te is x64-es W7-et használsz, én is. No mindegy is, nálam sose volt ilyen gondja (eddig más se panaszkodott ilyen jellegű hibára itt a fórumon), ez valami egyedi eset lehet, összeakadhatott valamivel.
HZoli87
HZoli87
válasz Fire/SOUL/CD #35650 üzenetére
4., Interaktív módban vírus találat esetén idegesítő system scan (kb. 30 sec)
5., OS indulásától számítja a frissítési időközt (2 óra), nem pedig az előző frissítéshez képest. Bekapcsolom a gépet, ekkor természetesen lefrissül a program, de utána újraindítom mindig 1 óra 50 perces időközönként és lám nem frissít, mert nem telik le a 2 óra, és ezt a végtelenségig képes csinálni. Na ez a legidegesítőbb hibája, kipróbáltam úgy is, hogy szűz OS és csak az Avira, akkor is így működik. (eredeti OS és Avira)-----
WebGuard részével én megvagyok elégedve, nem lassít jobban, mint ha a Kaspersky lenne a gépemen.
HZoli87
válasz BRosszQtya #35683 üzenetére
1x már megkérdezted és választ is kaptál. Itt megnézheted, hogy mit is tud az ingyenes verzió.
HZoli87
válasz blattida #35718 üzenetére
De nem sokkal. Olvasgatom a Comodos fórumot, hát vannak cifra dolgai (FP) ezen a téren.
Az nem semmi, hogy Avira milyet fejlődött ezen a téren, emlékszem régen jól űzték ebben a versenyszámban az ipart, most 1 hónap alatt 2 FP-ét dobott maximum beállításokkal, tűrhető.
HZoli87
válasz BlackSeven #35834 üzenetére
Fájl Titkosítás és Megsemmisítés: csak a Global Protection tudja.
catthomas: köszi.
HZoli87
válasz BlackSeven #35838 üzenetére
Oldalukon egyik ellentmondást követi a másik.
(legalábbis a magyar lapon)Itt a nemzetközi honlapjuk: Link
HZoli87
válasz BlackSeven #35888 üzenetére
Én is az Eset termékét telepíteném a gépre, a többi megölné kis túlzással a "gyenge" gépet. Ha a kettő közül kell választani, akkor egyértelmű hogy F-Secure.
HZoli87
HZoli87
válasz Fire/SOUL/CD #37171 üzenetére
Persze, tudom hogy így működik, nem most használom először. De kéri, hogy csatoljak fájlt, hiába írtam be az URL-t. De már megoldottam ...
HZoli87
válasz polonic #37175 üzenetére
Először a kivételek közé tettem az oldalt, meg is nyitotta a böngésző, de egyből jelzett a Guard, hogy a Temp mappában bajok vannak, de karanténból elküldtem a bizonyos fájlt, majd hétfőn javítják. Egyébként VT szerint csak az esernyős termék jelez rá, nyilván tévesen, de az ilyen megtörténhet.
(#37173) Fire/SOUL/CD: Guard is jelez rá, ha letöltődött a számítógépre.
HZoli87
válasz Fire/SOUL/CD #37246 üzenetére
W7 fut (x64), a program nem gyári beállításokon van, amit lehetett szigorítottam és bekapcsoltam. Kipróbáltam gyári beállításokkal, akkor is jelez az oldalra, vagy a temp fájlra.
De nem zárom ki, hogy csak nálam jelez az oldalra, bármi megtörténhet.
HZoli87
HZoli87
válasz Szellem. #37251 üzenetére
Attól, hogy 1 hete lezárult a béta teszt, és szeptember elejére ígérték a véglegest. Nézd meg a linket hogy mire mutat, nem fake. Gondolom hétvégén nem nagyon dolgoznak, még elkészítik a körítést (weblap frissítés ... ) és a sablon szövegeket, de jövőhéten fent lesz már a honlapon, bárki elérheti majd.
30 napos trial időszakot is gyönyörűen megadja.
HZoli87
válasz Szellem. #37271 üzenetére
Eddig teljesen jó, detektálása lehetne jobb is, de az nálam nem számít annyira, nem keresem a bajt. Gépet nem fogja, böngészés gyors, szép a GUI, gyors az ellenőrzés. Magyar változatra 1 hónapot kell várni kb., de majd jövőhéten kiderül, kiszoktál előre adni, hogy mennyit késik az adott nyelvi verzió.
(#37269) RBJ: 2009-es változattól a Norton termékek települnek szinte a leggyorsabban a PC-re, eltávolításra pedig van egy remek eltávolítójuk, ami pár perc alatt lepucolja a programot.
HZoli87
HZoli87
válasz Fire/SOUL/CD #37373 üzenetére
Legújabb adatbázis tartalmazza a változásokat, ennek ellenére még mindig blokkolja az oldalt.
HZoli87
válasz Fire/SOUL/CD #37378 üzenetére
Nálam az elsődleges és másodlagos is törlés + a karanténozás, ha netán falsolna. Most néztem végig, hogy miket és mennyi fájlt küldtem eddig elemzésre, és 1 év alatt csak 5 False Positive volt, ez elég jó egy ilyen magas találati arányú AV esetén. (első dolgom mindig átállítani a gyári beállításokat maximumra, úgysem fogja a gépet)
9-es verziónál még Interaktívra volt állatva minden, de az újnál igazán elhagyhatták volna az idegesítő System Scan opciót (ugyancsak interaktív módban), így minden vírus esetén 30 másodpercekig dolgozik a program.
- Perelnek a vallásos kripto-piramisjáték miatt
- Macska topik
- Formula-1
- hcl: Linx 1010, a gagyi x86 tablet újjáéledése
- Autóápolás, karbantartás, fényezés
- Bitdefender Total Security 3év/3eszköz! - "Tökéletes védelem most kedvező áron..."
- Megmaradt - Eredeti Humble, Choice - Steam kulcsok
- PC JÁTÉKOK (OLCSÓ STEAM, EA , UPLAY KULCSOK ÉS SOKMINDEN MÁS IS 100% GARANCIA )
- Adobe Creative Cloud - 2024. 04. 05 - 2025. 04. 05-ig
- Windows 10, 11 Professional, Home, Enterprise licenckulcsok 64, 32 bit - MEGA Akció!
- Need For Speed + minden más csak egyben
- Steam kulcs turkáló :: Friss Excel lista 1200+ játékkal :: Közte VR, AAA és indie címek olcsón!
- 3db eredeti PC játékok
- GameStar / PC Guru játékmellékletek tokkal és borítóval 500Ft/db
