- ZIDOO médialejátszók
Tényleg jön a The Thing: Remastered
gp Egyelőre nem kaptunk megjelenési dátumot, de elvileg még idén megkapjuk az új változatot.
Filléres Redmi érkezett
HZoli87
Csak egy kis olvasni való, Internet Explorer 9 (teszt verzió), ki is próbálható.
HZoli87
válasz HZoli87 #26401 üzenetére
És a változások, 64 bit alatt ProAktív modul nélkül.
Avira AntiVir Version 10 – Release Candidate 1
Changes and Fixes
For the English version please note that there are still some German messages in the product.
This will be fixed for the final release.
FIX "Improved License Enforcement" isn't fully functional
FIX "Product protection" option is in German
FIX AV9/AV10 presetup.exe Crash by silent Installation
FIX Scanner cannot follow links with system variables like %WINDIR%
FIX ARK: Not all hidden objects are detected and strange logfile entries
FIX AVGuard "write mode" is not working correctly on network drives
FIX AVIPBB not installed properly during upgrade from AV9 to AV10 on 64bit Vista and
higher
FIX Avira entries remains in WSC after cross update/deinstallation
FIX Avira Events contains messages in German for the English Kit
FIX BackUp report 0 Kb copy in the back-up location.
FIX Different information in control center and configuration center
FIX Different MD5-sum for same files/Lower Version numbers in AV10 than AV9
FIX Disabled process protection on all VISTA OS
FIX EN: GUI: Window at the end of the rootkit scan is in German
FIX FACT: Newsletter subscription fails due to wrong used language tag in http request
FIX Firewall: Current configuration not always shown in Configuration Center and
appcrash avconfig.exe
FIX Firewall: Different default values between fresh setup and after creating a new empty
config profile
FIX Firewall: Network adapter which are not usable for all OS user are not enumerated in
page "Adapter rules"
FIX Firewall: Sometimes the firewall configuration file is not kept to the belonging
avwin.X.ini
FIX German text in the English kit
FIX Guard crashes when pressing the buttons on slide up after a detection on mapped
network drives
FIX Guard enables process protection
FIX MailGuard crashes sometimes with SMTP + IMAP Mailbox
FIX MailGuard uses 100% CPU load when monitoring IMAP
FIX Minifilter is installed and running even if related module AVGuard was not installed
FIX Problems while probing installed SSDT hooks (Deadlooks and BSODs)
FIX ROOTKIT: Unknown error detecting a hidden registry key
FIX Setup: Firewall module installed and running but not available in avcenter, avconfig
and avgnt
FIX Slideup will be not shown in automatic mode
FIX SMC: English text in the Engine Service logfile
FIX Strange progress during scan
FIX support the Reset button in the same way as all other plugins
FIX The "OK" button of the MailGuard detection dialog has no 10 second timer
FIX Update over dial up broken after upgrade to AV10
FIX Virus-Slideup hides automatically
FIX VMWARE: ARK is used at vmware scan
FIX VMWare: Executing pre-scan script
FIX VMWare: The execution of the pre- and post-scan-script works not as expected
FIX Webprot init error <14001>
FIX When uninstalling ISEC "Next"-button is active
FIX Windows XP Mode does not work after installation Product with Firewall -
HZoli87
válasz BigManus #26427 üzenetére
Lehetséges, múltkor nem vettem észre. Mondjuk nekem Premium előfizetésem van, az kevesebb lesz ugye a tűzfal modullal. Webguard érezhetően gyorsult. A 25-ös build már szebben futott 64 bit alatt, mint a mostani elérhető legfrissebb 9-es. GUI végre optimalizálva lett, elég élmény romboló, hogy a mostaniban szaggat mint a fene (x64 alatt persze).
HZoli87
HZoli87
válasz polonic #26545 üzenetére
Nálam egyszerűen csak nem akarta magát aktiválni a program (KAV), így még a próba 30 napot sem kaptam meg (nem tudott csatlakozni a szerverhez, de net azért volt mellette), de szerencsére aktiválás nélkül is feltelepült. Frissített 20 megát, de a próbaidőszakot ugyanúgy nem tudta aktiválni, csak lámpázott, majd rá 2 perce hibaüzenet. 2 órát adtam neki, nem javult meg, utána töröltem a fenébe...
HZoli87
Heló !
Működik nálad rendesen az RC verzió Avirából? (32 vagy 64 bit alatt?)
- Nálam nem muzsikált túl jól, beállítottam ugyanúgy, mint a 9-es verziót (mindent maxra), így folyton jelzett a heurisztika (FP-ket generált, 20 megás avira, random részére egy adott torrentnek), eicar teszt fájlt 32 másodpercig törölte, addig ment egy ilyen állapot jelző ablak. (ilyet még nem láttam a mostani verziónál)[ Szerkesztve ]
HZoli87
Nálam minden interaktívra van állítva (így magától nem blokkol semmit sem auto módon a program), a tömörített eicar fájlt akartam letölteni, utána már nem is néztem, hogy mi blokkolta, csak jött fel az ablak (ahol eddig a frissítést jelző helye volt), ott remove, és ahogy említetted, egy system scan nevű ablak lámpázott, míg el nem ért 100%-ig. <- szóval ez akkor nem bug, így vagyon megírva.
- De a FP generálás jobban bosszantott, azért szedtem le a gépről, kezdte a torrent fájlokkal , majd a utorrent.hu-ról letölteni kívánt magyarosítás linkjét is blokkolta, amit a 9-es verzióval vígan megtudok nézni és letölteni. No mindegy, csak lesz valami ...
HZoli87
Csak az nem magyarosítja teljesen, csak részben a programot. Mindig frissítik folyamatosan a honosítást a magyar honlapon. Nálam sosem jelzett még rá a 9-es (Premium) verzió, lehet ez is a Security Suite miatt van. (ahogy az extrás oldalakat is blokkolja)
HZoli87
válasz sznorbi2 #26670 üzenetére
Norbi szerintem azt kérdezte, hogy ha egyedül ráereszted az Ashampoot a csomagra, akkor mennyi fájl marad és melyikek. De lehet rosszul értelmeztem a kérdését.
(mert ez az a 19 fájl, amit az F-Secure/Ashampoo páros hagy egymás után, szerintem)
(de lehet már késő van, és rosszul olvasok a mondatok között... )[ Szerkesztve ]
HZoli87
Mindenkinek köszöntem a linket, holnap újra is húzom a rendszert.
De azért megvárom, míg kiteszik a honlapra...
HZoli87
Észrevettem 2 érdekes dolgot, egyik hogy eltűnt a bejelentkezési képernyője az Avirának (RC-nek még volt), már újra telepítettem magát a programot, és a gépet is újraindítottam párszor. Másik pedig, hogy nem mutatja az utolsó frissítés dátumát, RC verziónál ugyancsak működött. Kezd rossz érzésem lenni a programról ...
HZoli87
válasz Szellem. #26781 üzenetére
Arra, hogy sorra jönnek elő benne a bugok ... (mondjuk még mindig nem hiszem, hogy ez lenne a végleges változat)
-Legalább FP-ket nem dobál, se a torrentre, se a többire...
Gorneck23: nem baj egyik sem, mert a program az jól működik, de múlthéten még működött az RC verzióval rendesen. (de majd a többiek leírják, hogy náluk mi a helyzet, nem lehetetlen, hogy 64 bit miatt ilyen ...)
HZoli87
válasz Fire/SOUL/CD #26788 üzenetére
Köszi.
(bugos kijelentésem akkor visszavonva, akkor működik rendesen, "más" hibát még nem tapasztaltam)
-Kíváncsi vagyok mikor rakják ki a hivatalos honlapra. Dolgozni dolgoznak, mert már 2 frissítés is megjelent ma.
HZoli87
válasz betyarr #26820 üzenetére
Nálam gyorsabb, mint a 9-es verzió. (főleg a boot és a bejelentkezés + WebGuard is sokat javult) Memóriából kicsit többet eszik, keresője is lassabb érzésre. Persze még dolgozhattak volna rajta, de sürgette őket az idő.
zed01: nálam sincs semmi bug, már megbeszéltük a többiekkel nem is olyan régen.
HZoli87
válasz Szellem. #26836 üzenetére
Érdekes, lehet hogy még nem kiforrott a cucc, 64 bit alatt nagyon szalad a program. 4 hónapja van meg az új gépem, ami már WIN 7-el érkezett. Azóta 1-2 naptól eltekintve végig Avira volt rajta, így gyorsan összetudom hasonlítani a kettőt. Proaktív nélkül ugye, gyorsabb a boot, az egész rendszer gördülékenyebb, internetezés az meg abszolúte szuper 9-es verzióhoz képest. Negatívum, hogy több memória kell neki, lassabb a scan. Frissítési hiba/fagyás még nem volt tegnap óta. Persze, ahány hardveres/szoftveres környezet, annyi különböző hiba forrása lehet. Reméljük azért még nem állnak le a fejlesztéssel és csiszolnak a programon.
(most újrahúzom a rendszert, pár nap múlva majd bővebben tudok majd nyilatkozni)
(csoda, hogy ilyen lett a program, pár hete még nem tudtam volna elképzelni, hogy így fog teljesíteni, lehangoló volt nekem is a véleményem róla)
(a 9-es verzió meg túl jóra sikerült, nagyon eltalálták)
HZoli87
válasz Szellem. #26839 üzenetére
Ha hiba van a gépezetben, akkor hiba van. Én se védem a programot. Megvolt a gép teljes telepítése (particionálás, update, összes program telepítése, töredezettségmentesítés). Windows Updateről jövő frissítések, driverek és pár program telepítésénél érezhetően lassabb volt, mint a 9-es verzió. Nem tetszik, hogy eltüntették az indító képernyőt és az sem tetszik, hogy nem mutatja a tray ikonnál, hogy mikor volt az utolsó frissítés. Most előjött egy olyan hiba, hogy letelt a 2 óra az előző frissítés óta, de elfelejtette újra frissíteni magát. Keresője bő 20%-al lassabb, nem vettem észre, hogy részletesebben keresne. Kb. ennyi a negatívum. Boot érezhetően gyorsabb, főleg a bejelentkezés és a program felállása. Programok telepítése és a töredezettségmentesítés után nem érzem, hogy lassabb lenne a működés, szemre és időre talán gördülékenyebb. Frissítéskor nem tapasztaltam semmilyen pillanatnyi fagyást. (ez még az előző rendszerre értem, mert most téli álmot alszik a frissítője) Böngészés egyszerűen gyorsabb és jobb, megnéztem a speedtest.net-et, oldalra érkezés után 2 másodperccel már választhatom is a várost ki. (semmilyen akadás) Lenne még mit csiszolni a programon, gondolom nem is állnak le a fejlesztésével. Nálam most is jól működik, de még pár hónapnak és pár új buildnek biztos meg kell jelennie, hogy teljesen hibamentes legyen a program. Körülbelül ennyi a verdiktem.
HZoli87
válasz polonic #26852 üzenetére
Ezek inkább csak megszokásból hiányoznak. Használhatóság rovására nem mennek, amúgy tetszik a program. Teljes keresés 19 percig tartott (régen 15 perc), és ebből 2 perc a rootkit scan. Egy leheletnyit lassabb. És nálam tegnap sem, és ma sem mutatja a frissítést, este 6-kor töltöttem le a telepítőt, amikor hazaértem, és 3 órás az OS.
És magától nem akar most frissülni, remélem holnapra megjavul.
HZoli87
válasz polonic #26854 üzenetére
Hát a Windowson és rajta kívül nem sok dolog indul a géppel. Valószínű a tűzfalas verziónál azért működik, mert azt lehetett tesztelni még béta stádiumban, és ott nincs ilyen hiba. A sima Premiumot és a Personalt összedrótozták és kivettek belőle ezt azt, hogy tartsák a határidőt. (Mintha Fire írta volna, hogy az ingyenesnél sem jelzi a frissítést a tray ikon)
- Végre befutott Xbox-ra is az Octopath Traveler II
- Call of Duty: Black Ops 6
- Moderátort keresek a fórumhoz!
- Ukrajnai háború
- Mobilinternet
