- ZIDOO médialejátszók
- Computex 2024: Íme a Project NeonStorm
Az EU-s bejegyzésekkel tréningezi az AI-t a Meta
it A Meta közölte: az AI tréningezéséhez ezentúl az európai közösségi médiás bejegyzéseket is felhasználják.
Az Xbox Series X|S konzolnak három új verziója jön idén
Path of Exile topic
tocsek18
tocsek18
tocsek18
tocsek18
6 trial helye:
Act 1 : Prison
Act 2 : Chamber of Sins LvL 2
Act 2 : The Crypt LvL 1
Act 3 : Crematorium
Act 3 : Catacombs
Act 3 : The Hedge Maze[ Szerkesztve ]
tocsek18
lvl32óta szívok labirintusban most vagyok 38 mindig sikerül egy fűrésszel párhuzamosan futni
tocsek18
chris_wilson Lead Developer10 minutes ago*
Okay, the server came back up immediately. The crash is being investigated.
tocsek18
új kereső hátha érdekel valakit:
What is ExileTrade?
It's a Free and Open Source Fan-made Website for searching of Path of Exile items. It features searching by search terms that are based on Path of Exile community jargons like 6s5L pure 70life 60res and 350pdps. You can also save all your searches, so you don't have to ever retype a search again that might be useful to you.
Features
1. Hand crafted Search Terms like 50life, 90eleres, pure, tabula.
2. Configurable Search prefixes(terms which will be added to every search e.g. the league).
3. Individual Item highlighting.
4. Search History.
5. Forgotten Mods - shows mod prefix/suffix, tier and max tier.
6. Boolean operators - allows searches that has never been possible before!
7. Search URLs simillar to Search Engines - this allows you to easily share queries.
8. 100% free and absolutely no-ads.Examples of advance searches:
1. purear 6s chest - [link]
2. rare (gloves or boots or helm) 50life 30fireres 30coldres 5c - [link]
3. (mace NOT voidhome) 350pdps - [link]Link to Site:
http://exiletrade.github.ioHow to Use & Example:
1. In the search bar try typing tabula 35ch and click the Magnifying Glass button (or press enter).
2. This should show you:
every Tabula Rasa
listed in Perandus SC (default league) using the stash API
with a buyout of at most 35chaos
sorted by price
3.Click the whisper button and a wanting to buy whisper message will be saved into your clipboard
4. Switch to Path of Exile, open the chatbox, and press ctrl+v.
5.If you want to change the league you want to search in click on the gear icon on the right side.
6. In the now open sidebar click on the league
7. at this point you can close the side bar by clicking the X, if you want to keep your changes for the next session as well you have to click the save button on top(for now will change in the near future)
Users of Durian will be at home to use ExileTrade as it uses most of it's search terms. We're still working on a document to list all the search terms, but here's a crude way to learn all the terms Edit: I've added a search term button at the top which lists all the possible search terms, we'll be improving this overtime. Note that we expect to find bugs as the project is very new.Tips:
1. Each of the item is actually a json a data, to view the json, you click on the item-art and some interesting data.
2. The json sent to ExileTools can be view by clicking on the small clock or document icons located on the left of the Search Text Field. This can for now, help you to understand how the search terms are parsed
Official forum thread: https://www.pathofexile.com/forum/view-thread/1602257[ Szerkesztve ]
tocsek18
itt állok secret passage merci labornál, ez a földön taposós sakktáblás 3 fajta jelest hogyan kéne kitaposni? bármit tolok jönnek a poison nyilak
tocsek18
válasz tocsek18 #6416 üzenetére
nah hát nem fogom farmolni izarot mercin
lvl 69 2h mara 32kdps 50dmg reduc 3,6k life 1hit csá, esély nincs körülötte ugrálni majd vissza nézek 85-90között több élettel és nem slotonként max 5c itemekkel aztán kiváncsi leszek
jöhet a mapfest
ha meg broken lesz akkor is akkor újbuild
ötlet? vélemény?[ Szerkesztve ]
tocsek18
ah kössz, kössz én csak random rámentem előtte a 3ra ide oda aztán mentségemre szolgáljon azért nem láttam melyik nyomódik le mert rajta feküdt vagy 4hulla mob tökéletes takarásban
tocsek18
nah léptem 6szintet lvl75ön 3.9k hpval fulbuff 43k dpsel full csöves grearrel 4link earthqueak, 76 52 60 ressel ,az ajánlott stibnite és granite flaskal egy helyben állva lefacetankoltam, tényleg op a smoke cloud
szóval most boldogság van -
tocsek18
elementalistból esetleg vélemények valami viable régi fire prolif dd build? vagy azzal se?
tocsek18
tocsek18
tocsek18
válasz Plazmacucci #6496 üzenetére
tocsek18
ideje lenne már a szerver packot bővíteni vicc, hogy megint beszartak
tocsek18
válasz Plazmacucci #6509 üzenetére
reduc mana, mana leech gem, mana leech curse, blood magic, elreon ring vagy amu, esetleg mind2
sok lehetőség van -
tocsek18
válasz Plazmacucci #6511 üzenetére
azok a kék szarok a játék legjobb lvling itemjei - manával augot neki ha jót rak rá mehet regal, vagy jó vagy kuka próbálkozni kell, de a faszákat el lehet adni drágán
ott a mana leech a ringen, vegyél olyat, vagy amit kihagytam vegyél olyan jewelt amin van mana leech
tocsek18
válasz Plazmacucci #6513 üzenetére
venni kell poe.trade-n majd ha mapozol vissza jön az áruk, esetleg esik jobb
tocsek18
sok baromnak fel se tűnik DD
tocsek18
ééés 3.jára szarnak be a szerverek
broken servers league
tocsek18
tocsek18
tocsek18
vandok drágák lehetnek főleg ha kell mind3 stat speell dmg crit multi project speed főleg hogy most mindenki ezt tolja
akkor ott a reflect bár arra ott a winktar poti az se olcsó ha kezdő vagy fél ex kb igaz az nem sok pénz
esetleg a biztosabb módszer a voltaxic bowos chaos spark ott csak nyomod az attackot és kiröhögöd a phis és ele reflect map modeokat
nah de ami a főszopás lehet azt a 6l armor, eleve 6link az nem olcsó RÁADÁSUL KELL BELE ÖT OFFCOLOR ami mit tudjuk vagy 30 chromatic alatt belemegy vagy 5000ből se ez lehet a legnagyobb szopóroller szerintem -
tocsek18
How is update 3.0 looking?
The 2.4.0 expansion probably comes out in September. We haven't talked (EDIT: *talked publicly*) about the plan for updates after that point yet.(2.3.0 technically isn't an expansion, just a challenge league and large content update, akin to 2.1.0/Talisman)
tocsek18
válasz Plazmacucci #6600 üzenetére
nézd meg ezt
olcsó és táp, 80-130k dps lazán megvan én próbáltam és ajánlom -
tocsek18
tocsek18
tocsek18
nah én örülök hogy chaos arc megy a kukába
voltaxic flipping királyok most beszopták, vissza is esett az ára felére, mondjuk én nem próbáltam csak azt sajnálom
ez alapján kb minden clastt buffolnak csak a scion sparker kap nerfet, kevesebb pierce és leech érdekes
jól látom hogy majd Inquisitor-ból jobban megéri majd sparkert csinálni mint scionból? Mondjuk piercet nem tudom honnan szed 100%ot templar gem armor jewel az csak 75 nah mind1 -
tocsek18
nem 75 hanem 90 fail
tocsek18
tocsek18
- Egyéni arckép 1. lépés: ARCKÉPHEZ VALÓ JOGOSULTSÁG
- Tudományos Pandémia Klub
- Motoros topic
- Microsoft Excel topic
